Side-Bending Jig Question
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=25257
Author:  samryan [ Thu Dec 31, 2009 5:37 pm ]
Post subject:  Side-Bending Jig Question
I'm working on my first guitar-building project and recently purchased the Fox Universal Side Bending Machine. I built the template-jig (photo attached) today but had a question before I try this out. Two of the steel rods aren't perfectly flush with the side leaves. In both cases, the circumference of the rods project about 1.5 millimeters beyond the top-edge of the side leaves. Is this something I need to fix before going live? In other words, will this tiny projection end up causing a crease (or bump) in the rosewood when I bend it to make the sides? Or will a projection that small not really make a difference once I clamp the sides into the mold after bending. I'm hoping that once I bend the sides and then clamp them into the mold, such tiny imperfections will be evened out. But I figured I should check first before I risk ruining a nice piece of rosewood. Thanks in advance for any advice.
Author:  Jim Watts [ Thu Dec 31, 2009 6:33 pm ]
Post subject:  Re: Side-Bending Jig Question
Greeting Sam and welcome to the forum.
Are you saying that the diameter of the steel rod is not tangent to the contour of you template?
Author:  samryan [ Thu Dec 31, 2009 7:04 pm ]
James -- thanks. And yes. That is correct. It is not perfectly tangent. Hopefully my pic below makes it more clear.
Author:  GregG [ Thu Dec 31, 2009 7:07 pm ]
Probably won't make a bit of difference, but I would fix it just because it would bug the you-know-what out of me.
Cheers,
Author:  Timcacca [ Thu Dec 31, 2009 7:27 pm ]
I would fix it, why take the chance that it will cause a problem.
Tim
Author:  bill stewart [ Fri Jan 01, 2010 7:02 am ]
I would file the holes down a bit to get the rods flush. Otherwise you could have a slight skew/twist on your finished bend.
My tuppence worth.
Happy New Year Eat Drink
Bill S.
Author:  bluescreek [ Fri Jan 01, 2010 7:40 am ]
If you are using a building mold or form you are fine and you won't need to do anything as the mold is what will determine the shape anyway .
Author:  Bob Garrish [ Fri Jan 01, 2010 1:51 pm ]
I'd grind it level, but as John says it won't really effect your side much (they move quite a bit no matter how well they're bent). If you ever try to make laminated sides, though, you'd best be sure your form is spot on.
